by Fruitcake007 Contributor
standard upgrade and buying a new phone
I was with Orange and transferred to EE Sept 2018.I was advised to start with a EE sim 12m  250 mb £11R.The phone is a Samsung Galaxy ACE 2   which is my own phone.
On my account it says standard upgrade available now.What are my options because I would like to buy a more up to date phone
7 REPLIES 7
Re: standard upgrade and buying a new phone
Text UP to 150 to see when & what.
when I TEXT 150 does that commit me to upgrading??
No. I wouldn't have suggested it if it did.
@Fruitcake007   If you eligible to upgrade then your options are what are you willing to pay ?  You can have any device at any price point it just comes down to how much you want to spend.
Thanks for your help can I buy a new phone though EE?
@Fruitcake007  Yes you can,  you can go to a store, order on line or call customer services.  You might get a better deal by calling but have a look in the EE shop ( top of this page ) to see what takes your fancy and then call.
Thanks Chris could you give me any suggestions just middle of the road kind of thing?
Sometimes I think  a i phone would be better [what are the advantages of one?]
