by freeflow Contributor
speed test data usage
Hi does anybody know a site/app which uses low data for speed test?does ee provide one?
7 REPLIES 7
Re: speed test data usage
Hi @freeflow
I just use the speedtest app.
Hi @freeflow.
Our Tech Care teams would usually advise using speedtest.net when they go through any troubleshooting steps.
Alternatively, you van download an app as @Northerner has suggested 🙂
Jon
it gobbles up data several tests today used over 300mb, about 50 mb a shot, which is to much.
by Brilliant Contributor
Why you doing so many speed tests anyway?
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
instaling booster aerials, up here in Scotland highlands mountains and all that a lot of places get only one bar if you lucky, so have a high gain areal solves that, but you need to point it and that requires speed test to find right directions, not much coverage without a booster and aerial
Thanks @freeflow.
Have you managed to find any alternative speed tests that use less data?
no still looking
