by BV
New Member
sim not provisioned after upgrade
just upgraded from samsung s6 to s9. notification says 'sim not provisioned' and i can't make calls. when i try it says 'not registered on network'
by Andrewworr Established Contributor
Re: sim not provisioned after upgrade
Good morning @BV, I hope you are well
I know how frustrating it can be when things don't work as they are supposed to.
I would advise contacting EE - you can view your contact options here
Also, if you urgently need to make phone calls, are you able to access a laptop or computer, a tablet or possibly (this may or may not work without the SIM card working properly) use the S9 on WiFi to use a service like Skype.
I hope this gets sorted as soon as possible. If not, come back here and I'll try my best to help further.
Enjoy your new S9, by the way, looks like a great phone! 😊
Have a wonderful day
Andrew
Morning @BV
Welcome to the community.
Is your old SIM card still working at the moment?
Where did you order your upgrade?
Speak soon, Leanne 🙂
