by Skilled Contributor
Skilled Contributor
signal box
Hi
I upgraded from an S6 to the Huawei Mate20 Pro.
In the beginning my signal was awful. Constant dropped calls and very poor reception. After fighting with EE for about 16 months, I was ready to throw the towel in and move carriers. The enticed me to stay and sent me a signal box. All my problems were solved. Great reception and not 1 dropped call. Fast forward to the beginning of this year when I get the Huawei, I was getting the same dropped calls and poor reception.. EE and the community here advised using Wi-fi calling. So I did for a while, then I remembered why I didn't use it with the S6. It was crap. (my personal opinion only).
So I want to use my signal box, but the new phone doesn't seem to 'connect' to it. With the S6 I had full bars all the time. But now, I'm lucky if I get 2 (with poor quality calls), I'm pretty sure I asked EE to 'link' the Huawei to the signal box, but it still wont get the full bars..
Please, can anyone enlighten me 😐
Tracy
13 REPLIES 13
by Ace Contributor
Re: signal box
Hi @Dragon_
Welcome to the EE Community,
If you give the technical team a call on freephone 0800 956 3146 from a landline they will be able to help you trouble shoot your signal box.
Skilled Contributor
Re: signal box
A land-line? Blimey. Haven't had one of those for a long time.
by Ace Contributor
Re: signal box
@Dragon_  Or any other phone that works.
Re: signal box
You don't need a landline to call an 0800 number: a mobile will do and it's free to boot.
Re: signal box
@Dragon_  You don’t need to link a device to the signal box.  Any device in range of that box will pickup the 3G signal it out puts, if I was to walk past your home I could use the signal it outputs. It’s not locked to just your devices on your account.
Have you set up your new device to use all or just 4G signals.
Skilled Contributor
Re: signal box
Hi..
Thanks for the replies..
I would use my mobile but as the signal is a bit unreliable, i'm reluctant.. Maybe I can use the chat thing...
I've just checked my phone and there is no option to choose 3G alone.. It's 4G/3G/2G auto only...
hmmm
Thanks for the replies guys 🤔
Re: signal box
@Dragon_
Have you tried searching the forums?
Both devices are different, they are made by different manufacturers and have different radio chips and antennas. They also have installed different firmware, so just because one has more "bars" than the other means anything.
Your newer Huawei device might pick up EE 4G LTE signal, and thus this is why it's not connecting to the 3G signal box fully/at all, because it's interior signal.
Skilled Contributor
Re: signal box
Well, I'm not sure what happened between yesterday and today, but the Huawei now has full bars!!
Looks like it fixed itself.. (crossing fingers)
Thanks for the help!
Skilled Contributor
Re: signal box
Spoke too soon..
After having full bars for a day and a half, we're back down to 1 or 2...
I'm at a loss
Tracy
Re: signal box
Hi @Dragon_,
As @Northerner said, your phone will prefer a 4G connection (when available) over the 3G connection from your signal box.
This means that your phone won't attempt to connect to the signal box if it's picking up a 4G signal.
WiFi Calling would be the best solution for you.
To activate it, connect your phone to WiFi and go to Settings > Wireless & Networks > Mobile network > WiFi Calling.
Skilled Contributor
Re: signal box
Hi James...
You know, this makes perfect sense.
Looks like my signal box is redundant...
Just a thought, will the phone use wi-fi calling when not receiving 4G? Or...
Thanks again
Tracy
Re: signal box
Hi @Dragon_
I do believe that is correct.
If your phone is not receiving 4G and Wi-Fi Calling is available this is would come into effect.
Thanks,
Katie
Re: signal box
@Dragon_   Just enable WiFi calling from within the device settings and leave it on.
