Highlighted
New Member
samsung s8 how to extend ringtone time before going to answerphone.
I have tried the solution on here but when I type 30 to extend to 30 seconds it remains at 20 seconds when I check it. does anyone know what I am doing wrong?
Highlighted
by Profile closed
Not applicable
Solution
Re: samsung s8 how to extend ringtone time before going to answerphone.
Hi, @john-s, and @Christopher_G,
I think you'll find that 20 second's is the maximum! 😊
Regards
mAh8v
6 REPLIES 6
Highlighted
Hi @john-s
Welcome to the community.
Could you post the code that you're typing in please?
When you do it, does it give you a 'divert activated' message (or something similar)?
Highlighted
by Profile closed
Not applicable
Solution
Regards
mAh8v
Highlighted
by Established Contributor
@john-s - An older thread i know, but this may be of help
https://community.ee.co.uk/t5/4G-and-mobile-data/How-can-I-extend-number-of-rings-before-phone-goes-...
EDIT: Checked Link...should be working now. Smiley Indifferent
Highlighted
by Profile closed
Not applicable
Hi, @Graeme2812,
The link you kindly provided!
Is misconfigured! Because won't Open! 😞
Regards
mAh8v
Highlighted
@Profile closed - Strange, not sure what happened with the link. Should be working now.
Highlighted
by Profile closed
Not applicable
Hi, @Graeme2812,
Nope! Just tried it "error message", INVALID!!
As you've already mentioned the link is very old!
I know the "ring-tone" can be ajusted in 5-second increments! It's the dail code I was looking for originally, for someone else 😉
Regards
mAh8v
Regards
mAh8v
