by ns70 Investigator
samsung s7 screen
My quite new (a month old) Samsung S7, has developed a problem with the screen. A green line has appeared on the right side of the screen, also last night half of the screen disapeared, and was replaced with a white screen, so couldnt type in password or do anything. I managed to clear it by opening the settings at the top of the phone and change a setting this seemed to reset the screen, but the green line is now a permenant feature. please help
7 REPLIES 7
by Ace Contributor
Re: samsung s7 screen
Have you dropped the phone at any point?
If there is no sign of damage this would be coverd under warranty.
Book it in with either EE or Samsung direct.
BrendonH (Android Expert) - Samsung Galaxy S10+ (Pie 9.0)
If I have helped you please click on the STAR/SOLUTION buttons below
by Legend
Legend
Its either a hardware (screen/motherboard) or pixel fault. dial *#0*# and switch between the colours to see if you can make it disappear.
If not then you will need to take into EE for them so repair or contact Samsung and claim under your warranty if still valid.
Thanks,
Thank you, no it hasnt been dropped and no physical damage to the phone, was hoping I would be able to fix it without having to sent it off, thank you for replying
Thank you for your suggestion, the green line is still there when I followed your suggestion and changed the colour, thank you for taking the time to respond
Many Thanks
Hello there @ns70
Welcome to the community.
Are you with us on pay as you go or pay monthly?
Speak soon, Leanne.
Good afternoon Leanne
The phone is on a pay monthly contract
Many Thanks
Great thanks @ns70
I have sent you a private message on here to get some details.
Thanks, Leanne.
