by tjlemon
samsung galaxy j5
have just turned on phone but can't use it until i "draw a pattern". what pattern?
by Brilliant Contributor
Re: samsung galaxy j5
Hello @tjlemon,
Welcome to the community,
I believe this is a pattern for security, which you have to make. You should be able to get the manual and download it for your phone and it should then explain what you need to do.
I believe this is a log-on password for your phone.
