by searchingsoul
"NFC" and "Sync"
I am a PayAsYouGo customer. Will I becharged when "NFC" and "Sync" are enabled?
EE Employee
Solution
Re: "NFC" and "Sync"
Hi and welcome to the Community @searchingsoul
You would not be charged for having NFC activated, Having Sync activated will use data out of your relevant bundle.
If you don't have a bundle you would be prompted to purchase one.
Hope this helps,
Lee
EE Employee
Solution
Hope this helps,
Lee
by searchingsoul
thanks for the quick response. It is much appreciated.
EE Employee
