by Naseem22 Investigator
phone won't connect to incoming or outgoing calls ?
I have full recetion.. my bill has been paid.. but my phone won' connect to any incoming or outgoing calls..
7 REPLIES 7
Re: phone won't connect to incoming or outgoing calls ?
Try restarting your phone.
Also check your local mast for issues here
I have restarted my phone which didn' help
If checked for any problems and it's says there are none
Good Morning, @Naseem22
What is the make and model of your phone?
We'll do our best to help.
Good morning
I have a Samsung 7 edge..
Im receiving text fine and my data is working.. but everyone I try to answer a call or someone answers mine it disconnects.. I can' even ring 150
Thanks, @Naseem22
Do you have WiFi calling switched on?
If so, does it only seem to be when you're connected to WiFi?
Please also make sure that the network mode is set to automatic:-
  1. Tap Apps.
  2. Tap Settings.
  3. Tap Mobile networks.
  4. Tap Network mode (display will show current setting).
  5. Tap required option, either 2G/3G/4G (auto connect), 2G/3G (auto connect) or 3G Only.
Let me know how you get on.
Chris 🙂
Hi Chris
The wifi calling is off and the network is set to automatic..
Iv turned wifi on and off
The data on and off
Restarted my phone
Still having the same problem
Thanks @Naseem22
I recommend getting in touch with our technical support team.
They'll do their best to get this sorted.
