by happyhibs62
nougat on htc10
Anyone have a clue when Nougat is coming to  HTC10?
Getting sick and tired of EE and their unbelievably slow roll-outs, really regret re-newing my contract!
Solution
Re: nougat on htc10
You will know then any update is available as your phone will tell you. EE don't say when they will release firmware updates.
Thanks,
Solution
Re: nougat on htc10
Thanks,
by Profile closed
Not applicable
Re: nougat on htc10
The HTC 10 is now out of production.
You will be lucky to see a Nougat update on the HTC 10.
And you can pretty much forget any VoLTE implementation.
If you want a handset with access to the latest updates made in a sensible and timely manner you've got a couple of choices:
1) Go over to Apple. They will not have any restrictions on updates
2) Leave EE and go onto another network.
VoLTE and Wifi calling etc are great but no use if EE will not release the updates needed.
by Star Contributor
Star Contributor
Re: nougat on htc10
@Karen_C i see in another thread you said this should be resolved in the OS 7 update
Can you confirm for this customer.  You can see the frustration.
Is the OS update out and do these features work?
