by Pradeep62 Investigator
new simm for my samsung phone
hi i have got new sim as got samsung j5 phone but want to keep my old number what is i need to do this as am payg customer on £10 1 gb plan
cn get  a resposne asap please
10 REPLIES 10
by Brilliant Contributor
Re: new simm for my samsung phone
Is your old number also on EE?
Can you not just put the current sim into the device?
but my old phone is a sony aqua
thus sim is difftent
When you purchased this new phone did the advisor not say you can get a sim replacement to move the number and all that across?
You cant port a number to a new sim any other way.
Is your current PAYG plan on EE already?
If so ring up EE and ask for a sim replacement and that you need a micro sim to fit your new device.
@Pradeep62   Use THIS to order replacement SIM card of the correct size  this will keep your number.
hi
thaks
have got the sim replacement is best i go to ee store and ask them to do iit
@Pradeep62  why not just call customer services now and get it started.
EE Employee
Hello @Pradeep62
You can also use the Online Form to activate your SIM.
Thanks - Karen. Smiley Happy
sim issue
Have  been  too ee  store  Oxford street  to ask  if the transfer  my 're number  to my new ee  sim as want to keep my number  was advised need change provider I think the person  not aware of what  to thus  said this  do Ee  not want me as loyal customer
Re: sim issue
This is the same with every network.
You can't just swap numbers via sims.
EE Employee
Re: sim issue
Morning @Pradeep62
As @Chris_B advised if you have taken out a new EE contract you can't transfer a current EE number onto this contract.
Porting within networks is not allowed.
You would need to port your current EE number to another network then port it back in to EE.
