by tryinghard Investigator
my phone wont let me in does that mean its locked?
my phone wont except my password or face to log in
Solution
Re: my phone wont let me in does that mean its locked?
Thanks to everyone who tried to help me solve why my phone would not let me log in. I finally managed by letting it run down so when I refilled her with new juice it seemed to clear whatever was stopping her opening. Before that I could not switch it on/off or restart so that was a last resort. It worked so all good now, thanks
12 REPLIES 12
Hi @tryinghard
Are you sure it's your phone? It doesn't recognise your face, or password?
What device do you have?
@tryinghard    If you don’t know the password you’ll have to factory reset it.  You will need to know your Apple/Google account password and account email address.  depending on the device type.
Hi @tryinghard.
Welcome to the community.
What phone are you using?
When were you last able to get into the phone?
Jon
Yes it  is my phone. It is a Samsung J4+ I think. I get brief view that someone has tried to ring me before it switches off. The last thing I did was send a message to my daughter.
It is the correct password because I have sometimes seen that someone has tried to phone me before it switches off. I have also deliberatly put the wrong pass in and it has told me that it was wrong.
it is a Samsung J4+, I think. I got in yesterday morning to send a message to my daughter.
Hi @tryinghard,
What happens when you enter your password?
Solution
Thanks for the update @tryinghard
Glad you got it sorted. 🙂
I have now managed to solve the problem by letting the phone run out of
power and then refill. Before when I put my password in it switched on
briefly then turned itself off.
[image: Mailtrack]
Sender
notified by
Mailtrack
25/09/19,
09:17:51
So am I as I am going away for a few days at then weekend. Thanks
[image: Mailtrack]
Sender
notified by
Mailtrack
25/09/19,
15:24:52
Hi @tryinghard
Glad you have resolved this 🙂
Hope you have a great time away.
