by EllieToogood92
New Member
mobile data isn't working.
My mobile data isn't working. Only seems to be working when wifi is enabled. Is there an outage in my area. Anyone know any way to fix this please
Re: mobile data isn't working.
Hi @EllieToogood92
Check EE Network Status Checker. .
by Freddy1000 Investigator
Mine has been none existent for two days, there is an outage in my area nottinghamshire, and it was country wide as of yesterday, i also have the problem of calls dropping continuously .
Try this link and put in your postcode, where you can request updates on the progress .
https://myaccount.ee.co.uk/networkchecker/checkservice
