by davalco1 Investigator
message forwarding
How do i set up automatic message forwarding from one EE number to another, simmilar to call forwarding ??
Re: message forwarding
Hi @davalco1
What device do you have? By default you cannot normally forward SMS messages on Android automatically. You might be able to download an app which can provide this service.
I have both i phone and samsung s9
What i want to do is forward ALL the calls and texts from one sim to another (i phone to samsung ) but can swap the sims about as required
the idea then being i can forget about the i phone (switch off ) and just use the samsung
