by Mia65
increase rings before divert on Nokia 3 android
Hi, how can I increase the time to 30 seconds before my phone diverts to voicemail? I have a Nokia 3 Android.
Re: increase rings before divert on Nokia 3 android
@Mia65  Hi,
To change the length of the ringing before your voicemail picks up the call you can dial this number from your device.
**61*07953222222*11*25#
The 15 number at the end of the number is the length of time that your device will ring for before the voicemail takes the call . You can change that 15 number to any number in fives.
Like this
**61*07953222222*11*15#
**61*07953222222*11*10#
You can change it to no less  than 5 and no higher than 30
if it doesn’t work put your Sim card into a different device and try again as this doesn’t always work for some unknown reason.
by Mia65
Hi, thank you for your help.  I have been speaking to ee and apparently they have changed the amount of seconds before the phone diverts to voicemail.  The maximum is now 20 seconds!  We no longer have the choice of 25 or 30 seconds, which is a bit ridiculous as 20 seconds is not long enough.
