by GeoffE80 Investigator
how to watch Netflix on my tv instead of my android phone
Solution
Re: how to watch Netflix on my tv instead of my android phone
Hi @GeoffE80,
We will not stop you from tethering other devices to your mobile device. However, the EE Video Pass is not designed for this type of use and so we cannot guarantee that any data you use when tethering will be zero rated.
7 REPLIES 7
Hi @GeoffE80
Search Google.
Connect your TV to WiFi and watch Netflix. EE data pass only offers free data in devices.
by Ace Contributor
hi @GeoffE80  Are you trying to use your phone data, maybe a swappable pass but watch on your TV?
If you have a smart TV, they usually have a Netflix app you can launch, but then it won't be using your phone data.
If you can explain what scenario you are trying to do here, we can see if we can help.
I don't have a landline/broadband, so I use my Nokia 8 as an hotspot so I can connect my Panasonic smart tv to the internet. I have an EE 4g smart plan on my which I can watch Netflix on the phone. I was hoping to using the Netflix app on the tv. not sure how it will affect my data allowance or comes out of the video pass included
I have an smart plan which includes a video pass, I use my phone as an hotspot. do I need to logged in to Netflix on the phone & Tv at the same time.
Solution
Hi @GeoffE80,
Thanks for this
Cheers !!
