by noikan83
how long does it take for SIM to be activated after upgrade?
I was wondering if anyone knows how long it takes for a new SIM to be activated after upgrading to different plan? I got my new phone and SIM card on Friday and it has been 4 days now and still "no service". My old SIM still works so I am not without a phone, but just wondering how long it usually takes, is this normal or do I need to start pestering EE to act? Thanks!
by Profile closed
Not applicable
Re: how long does it take for SIM to be activated after upgrade?
If your old SIM card fits and still works, just continue using that after upgrading.
Hi @noikan83,
It depends on where you purchased your upgrade.
Please take a look at our SIM activation guide for more information.
by noikan83
Thanks for the replies, both. I have a new phone where my old SIM does not fit, so I have to keep using my old phone (which is broken) so not ideal..
I will try the simswap service and see how it goes.. Thanks!
No problem @noikan83
Let us know if you have any problems.
