Highlighted
google pixel 2 xl Finger print Scanner not working
Hi The other day i noticed my Finger print scanner is not working, i have had the phone just under a year
Also the Pixel Imprint opition is missing from my settings menu, so far i have booted into safe mode to see if anything wasnt working correctly and also reset it to factory settings.
I have seen on multiple websites that this is more likely a hardware issue, and is it covered by the warrenty is this correct?
And do you have any advice to get it working again!
Cheers
Callum
Highlighted
Re: google pixel 2 xl Finger print Scanner not working
Hi @53b
Contact Google and claim under your warranty, or take the device into EE for it to be sent for repair. If there is any other defect to your device, it  may not be repaired, or you maybe charged.
