by Andrew_Fishburn Established Contributor
eSIM on S20 Ultra
Hi.
Do we know if the S20 Ultra will get eSIM support on EE, I know iPhones have eSIM, but I've never used Android with an eSIM. I have used iPhones with an eSIM. I bought the phone unlocked directly from Samsung as I only wanted to  pay for it over 12 months, not over 24 months.
Solution
Re: eSIM on S20 Ultra
Hi @Andrew_Fishburn.
eSIM will be supported on the S20 on EE 🙂
Jon
10 REPLIES 10
Hi @Andrew_Fishburn
Given the relationship between EE and Samsung I would hope this is supported.
by Ace Contributor
EE support eSIMs on Pixels, so hopefully it won't be too hard to add the S20 to the list.
Solution
Jon
by Dazzabird Established Contributor
Is this by default....esim ?
therefore If so are the s20 dual sim ?
thanks
The S20 Ultra supports eSIM with a physical sim. Like the iphone XR, XS
etc. So yes, they are dual SIM
Ok what about the s20+ 5G version....is that Esim
by Chattoe Contributor
I would also like to know If the S20.+ has Esim, I believe it does but confirmation would be great.
i would then able to have my cake and eat it with my personal sim as my Esim, work sim as physical and then an SD Card
Good Afternoon @Chattoe
I can confirm the Samsung S20 will support eSIM.
Katie 🙂
by John103
New Member
Hi, for those of you still unsure about this topic as there is conflicting information floating around,  I have a standard sim and an esim installed in my Samsung S20 5G, both running actively. The esim account was done in a couple of minutes on receiving the QR code in the post from EE.
Thank you for letting everyone know @John103
Leanne 🙂
