by Simon56
dropped samsung galaxy a3 into water
i have removed simcard and opution bag of rice.
but phone wont shut down just keeps buzzing every few seconds tries to power up, shows first screen then goes black again, then repeats. should i try to shut down if so how?
by Profile closed
Not applicable
Re: dropped samsung galaxy a3 into water
The best thing to do is just leave it in the bag of rice for a few days, but TBH, it sounds like your handset is terminal unfortunately.
If you can, remove the battery, but otherwise just leave it as trying to press any buttons will just make things worse.
by Simon56
thanks will see how i get on
