by jeffrush2 Contributor
downloaded files
On my galaxy S5 when receiving an e-mail with picture, it says to save picture download to download file. I do not appear to have a "download file" folder, has anyone an idea how to bring up the Download file?
Solution
Re: downloaded files
You should have a Downloads app. If it is not on the main screens look in the Apps list.
Also you'll find it under My Files / Download.
6 REPLIES 6
Solution
Let us know if you find it @jeffrush2 based on the very helpful answer from @XRaySpeX
Thank you
Richard
by Ace Contributor
Also, if you have Google Photos, (or download from the Play store if not), select Device Folders from the menu and it'll show you all the folders with pictures on the device.
Any pictures you save in any folder will still show in your gallery, the folder holding the images will be shown there.
Great advice @Northerner
Richard
