by ynot68 Established Contributor
does the Galaxy S8 have voLTE
Hi does anyone know if the Galaxy S8 will support voLTE. I have been looking at specs on the web and according to one site  the s8 doesnt whereas the s7 edge does. Anybody shed any light on this.
by Brilliant Contributor
Solution
Re: does the Galaxy S8 have voLTE
Hello @ynot68
Thank you for taking the time to visit the Community. Smiley Happy
The Samsung Galaxy S8 and S8+ will support VoLTE (4G Calling) and WiFi Calling, this was announced by EE on their newsroom hereSmiley Happy
9 REPLIES 9
Solution
Hello @ynot68
Just to add to @Inyourbox the S8 will only work on VoLTE if bought direct from EE.
VoWiFi will work regardless where purchased.
many Thanks
Many Thanks
by Bosshogg Established Contributor
If you have an unlocked variant bought direct from Samsung ( usually Fw version BTU in the UK), or from elsewhere, you need to flash EE's firmware ( Fw EVR) to enable VoLTE.
This is quite simple and their firmware does not carry any bloat or boot logo etc.
My current S8 was from Samsung direct and I did just this.
Electronic Engineer by day.
Geek by night.
by Sumoalowaish
New Member
How do I flash the EE firmware?
Search Google.
No one here will or should tell you how as you could end up bricking your phone rendering it useless if you make a mistake and we or EE will not take any responsibiliy if this happens and it would most likely trip Knox and void warranty.
There are plenty of guides out there on how to do it though.
by Expert Contributor
Expert Contributor
My unlocked / SIM free Galaxy S8 (XEU) had a firmware update to version CRC7 and VoLTE now works on EE without the EE firmware.
Same here
Now receiving VoLTE
