by RMcontacts
contacts
how do I save my contacts on the web from my sony experia so i can buy a new phone?
EE Employee
Solution
Re: contacts
Hi @RMcontacts
Just to add to @Chris_B's advice if you have a Gmail account you can use that to transfer your contacts.
If you need any help there's some good info on the Sony Support forum.
Thanks - Karen. Smiley Happy
Re: contacts
@RMcontacts  there are many apps that you can download that can copy your contacts lists, you then email this to yourself  and then once you get your new device you open the email on your new device and install the contacts from that email.
EE Employee
Solution
Re: contacts
Hi @RMcontacts
by RMcontacts
Re: contacts
thanks
EE Employee
Re: contacts
No problem @RMcontacts
If you need anything else let us know!
