Highlighted
can't access data roaming
For nearly two weeks I have not been able to access data roaming I have performed a factory reset. I have taken out the sim card and put it into another phone albeit  the same make & model an alcatel pixi. Anyone got any ideas how to get data roaming again???
Highlighted
Re: can't access data roaming
Hi @Huffler
  • Are you PAYG or pay monthly?
  • If you are PAYG when did you last make a chargeable call or text?
If you are pay monthly or SIM only then log into your online account and activate roaming and international calls (Menu - Manage your device).
Highlighted
by Ace Contributor
@Huffler  Have you text ‘roaming’ to 150? Ensure it’s enabled on your device settings too.
Highlighted
Hi @Huffler.
Welcome to the community 🙂
In addition to the questions you've been asked already, what country are you currently roaming in?
Have you been able to get it working previously?
Jon
Highlighted
Thanks for the reply
I've had to phone EE to get it sorted. It was quite complicated and resulted in them having to do things at their end.
Huffler
Highlighted
Hi @Huffler
Thanks for coming back to us.
Is this now working for you, after speaking to us?
Hope you're having a great time 🙂
