by TECHmobile Contributor
back up for my Samsung A3
Dear all, i'm now in my third day ,
of tinkering .. last night i did a trial wifi backup and i found that picture that i took moved from my gallery to my photos storage ..
currently my photos and g+profile im using as a buisness platform , so you can guess why i don't want my pictures on there .
how do i make it so that so it move's  to either my Drive  or Oncedrive or another storage entity ...
any tips or hints ?
from Tech
EE Employee
Solution
Re: back up for my Samsung A3
Hi @TECHmobile
Your photos will only be visible to yourself in Google+ it's only if you shared them with someone that they could view them.
There's a handy page on the Samsung website will info on how to back up - What are the different methods to backup or transfer data from my Samsung Galaxy device.
Hope this Helps!
Thanks - Karen. Smiley Happy
9 REPLIES 9
Hi @TECHmobile,
What are using to backup your pictures? Google Photos?
They shouldn't automatically be visible in your Google+ profile.
by Brilliant Contributor
They will show in you G+ but you will see them unless you publish them.
Well the image went from from my gallery to the Google + photos how do I know if it's visible or not visible .. ? .. as I can't see my profile externally  ..
Tech.
Hi Brendan, I'll try another wifi with a image and see what it puts it as ..
I did another mock picture take , and wifi plugin .. the picture .. goes as i say from my gallery on my phone to my google photos,  i've been on the photo in the storage in photos and i can't see how it's been set private or viewable to public ????
so i still need help on the backup issue ?
I'm back with a idea how do I disconnect my wifi charging , so the pictures don't go to photos all I will do is move them manually to drive ( Private) ... ? ...
EE Employee
Solution
Hi @TECHmobile
Hope this Helps!
So Karen photos on my photos storage .. can only be viewed by me correct ? .. and other people even if they are following my business Google + can not see them unless they receive a shared image .... ?
am I right .. ?
That's right @TECHmobile.
You need to share the photos via your Google+ profile for others to view them.
