by printerman123 Investigator
Xperia 1 streaming problem
can't stream YouTube....prime or anything ....works for few seconds... then buffers then starts but with no sound..... and does it after exactly same amount of time b4 buffers....if i go on to airplane mode then off it works fine........but  only for short time..... tried in various areas that I knew worked fine with last phone and wife's phone streams same stuff fine...... also any settings to increase be brightness?.... style apps open and brightness is brilliant..... other apps screen is dull
6 REPLIES 6
Re: Xperia 1 streaming problem
Hi @printerman123
  • Make sure your apps are updated
  • Are you using WiFi or EE 4G network?
  • Are you pay monthly or PAYG?
all apps updated
contact
4G....full signal
YouTube etc stops exactly same place every time .. then starts no sound.... same with prime etc...sat in car  and wife's phone... on EE played exactly same thing perfect...Sony zx premium.....
Hi @printerman123
You probably want to check out the official Sony forums as there seems to be many people with issues over 4G etc.
Good Morning @printerman123
Welcome to the EE Community 🙂
Is your phone on the latest software?
Have you been able to follow the advice from @Northerner and look at the Sony forum?
Speak soon,
Katie
everything up to date.....etc etc ..... makes phone next to useless other than calls and texts... and I could buy a PAYG handset for my monthly contract please price for that
Hi @printerman123
Thanks for coming back to us.
I have sent you a private message for further information, please take a look and get back to me.
Katie 🙂
