by LightningMe
Will a Xiaomi Mi Max 2 work on EE?
Hello
Advice please.
I'm looking for a new handset and have got the best contender for my needs.  However, as I have to order it online I need to know if it will work in the UK on EE (and also when I go on holidays as a normal person would!)?
The specs are (all gobbledygook to me)
Phone: Xiaomi Mi Max 2 phablet
Language: Multi languageÂ
SIM Card Slot: Dual SIM,Dual Standby
Feature:ÂGPS, A-GPS, Glonass, Beidou
Bluetooth: 4.2Wireless Connectivity: 2.4GHz/5GHz WiFi,3G,4G,A-GPS,Bluetooth,GPS,GSM,LTE
Network type:
GSM+CDMA+WCDMA+TD-SCDMA+FDD-LTE+TD-LTE
2G: GSM B2/B3/B5/B8
CDMA: CDMA EVDO:BC0,CDMA: BC0
3G: WCDMA B1/B2/B5/B8
TD-SCDMA: TD-SCDMA B34/B39
4G: FDD-LTE B1/B3/B5/B7/B8
TDD/TD-LTE: TD-LTE B38/B39/B40/41
CPU: Qualcomm Snapdragon 625 (MSM8953)
Cores: 2.0GHz,Octa Core
GPU: Adreno 506
Can anyone tell me (in simple English) if this will work in the UK on EE as it's an import from China but is classed as a GLOBAL VERSION and I don't want to change providers only handsets and nothing EE offers is what I am looking for.
Thanks in advance folks 🙂
Re: Will a Xiaomi Mi Max 2 work on EE?
Hi @LightningMe
Welcome to the community. 🙂
Yes, the device will be compatible with the EE network, please use the correct SIM slot. Smiley Happy
