by Ian_R
Will a Nokia 5 not purchased from EE work with wifi calling?
Hi everyone
I'm about to purchase a sim free phone and have been looking at the Nokia 5 as it is on the list of those that support wifi calling on EE.
Can anyone confirm whether this device, if bought indirectly will work?
by Brilliant Contributor
Re: Will a Nokia 5 not purchased from EE work with wifi calling?
If the Nokia 5 is a UK model then yes it will work with Wi-Fi calling.
