by stevebain
New Member
Wifi Calling Samsung S7 unstable on Nougat
Hi All, Since getting the Nougat update on an unlocked Samsung Edge S7 I notice my wifi calling is not reliable and often doesn't even connect whilst on wifi. It was working great up to the update and just wondered if anyone else has had the same problem.
Many Thanks.
by Brilliant Contributor
Re: Wifi Calling Samsung S7 unstable on Nougat
@stevebain it's EE there wifi calling is not working properly at the moment
