by Brilliant Contributor
Re: WiFi Calling on S7 Edge (3rd Party)
Also @red74eric I did say the other day we'll get your Wifi calling working but it may be a trek 😛
We got there though.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10 Beta)
by red74eric Contributor
Its been a trek Smiley Happy but also a good learning experience, so thank you very much for all your help and advice.
EE Employee
Glad you are sorted @red74eric 🙂
Many thanks for your help on this one @BrendonH
Cheers
Lee
No problem @Lee_H
by Suryia
Hi everyone
Same problem, no wifi calling on my S7 edge bought from a third party and was told i need to buy a new phone from EE which I cannot afford 😞
I work from home and have zero reception where i live so wifi calling is really a must. I am not super high tech but i can follow instructions 🙂 I would be super grateful for some advice and guidance.
These are the numbers I get :
AP: G935UUEU4BRD1
CP: G935UUEUBRD1
CSC: G935UOYM4BRD1
Have no idea what they mean or refer to and not sure if same solution applies to me, to install BTU firmware from Sammobile?
Please help !
many thanks
S
You have USA TMK firmware.
Yes installing BTU or EVR firmware will do he your issue.
by Suryia
Thanks a lot, I will give it a shot and feed back.
by alexlush
New Member
Just for anybody still struggling i can confirm that in my case my handset was supplied by O2 originally. Upgrading the firmware to BTU did NOT enable WiFi calling, however upgrading to the EVR (EE) version DID.
Also check with EE to make sure that WiFi calling is provisioned on your number as well.
Thanks to everybody who contributed to this thread! 😁👍
Recent solutions
