by Chelsy Contributor
Why wont phone connect to the signal box
My signal booster is on a sokid green light but i have no signal at all??
Re: Why wont phone connect to the signal box
@Chelsy  Have you tried restarting the router?  Leave it off for 30+ seconds and then switch it back on.  You could do the same with the signal box also at the same tone.
Hi @Chelsy
Did @Chris_B's advice of restarting the router help?
