by Umihani
Why is my note 9 not charging.
  1. I have tried to charge my phone with different chargers but its still wont charge.my phone is 7 weeks old. If the charger does work it says moisture detected my phone has never got wet.
by Umihani
Solution
Re: Why is my note 9 not charging.
I dont have a wireless charger i havenot tried that. 4 days a go the same thing happened but the phone started to charge after 4 hours but today its not charging and it also doesnt show any moisture detected nofication
The charging port is clean.
Hi @Umihani
Can you make sure the port is clear of any dirt or fluff. Does it wireless charge?
This warning doesn't necessarily mean your phone is wet, but can be as a result of humidity, sweat.
You are best contacting Samsung and going via their warranty program, or take your device into EE and they will send it for repair.
by Umihani
Solution
Thanks for confirming this @Umihani.
Have you followed the advice provided and contacted Samsung?
Speak soon,
Katie 🙂
