by J2talo
New Member
Why is my Samsung S10e not accepting my sd card?
I've just purchased the S10e and trying to use the sd card from my old S7 but its saying it needs to format the card first and that will mean losing all my data! Help!
Solution
Re: Why is my Samsung S10e not accepting my sd card?
Hi @J2talo
Copy your card data onto your PC, then allow your new device to format your card, then copy any data back into your card.
Solution
Hi @J2talo
