by Akerr Established Contributor
Why is my HTC phone showing my wifi network as a mobile hotspot
 Hi everyone I have a ee bright box 2 and i noticed on my htc phone that my wifi network is showing as a mobile hotspot and I'm just wondering if this is normal as i know I didn't set any hotspots up myself DSC_0007.JPG
Re: Why is my HTC phone showing my wifi network as a mobile hotspot
@Akerr: Does your HTC have a separate section for WiFi networks? Does your Brightbox appear under that?
If it does't have 1, maybe it lumps all WiFi networks under Mobile Hotspots.
by Skilled Contributor
Skilled Contributor
Or HTC uses a weird detection method for mobile hotspots.
It sees EE as a mobile xarrcar and goes "well an EE device must be a mobile hotspot".
Can you change the device name? Along shot but worth a go.
Hi @Akerr
Please see the advice above and let us know if you have any more questions about this. 🙂
Yes, you may change the Wireless Network Name (SSID) under Basic Settings / Wireless Settings.
Must be cuz EE is predominantly a mobile purveyor Smiley Wink.
by Expert Contributor
Expert Contributor
It's not telling you that your router is a mobile hotspot it's asking you to tick the box if it is. It's part of Android. On Samsung phones the menu is called Restrict Networks.
