by jrp1950
Why is my EE Harrier's clock losing time? Setting is for automatic date & time
My EE Harrier's clock is losing time when my phone is switched on - about 5 minutes per hour. my settings are for automatic date and time. if i switch the phone off and on again the time resets correctly but then begins to lose time again. Battery charge appears to have little to do with this.
10 REPLIES 10
Re: Why is my EE Harrier's clock losing time? Setting is for automatic date &amp
@jrp1950  Turn off automatic as this is not relevant to the uk as there is only one time zone in the U.K.
Automatic date and time is not just about time zones. It's for syncing with a time server on the Net. Anyway we do have GMT & BST.
Sounds like that's working by syncing at switch-on but the phone itself is faulty by losing time thereafter.
Oh sorry I didn't realise that we are not able to adjust clocks manually because of BST time. The whole of the UK has 1 time zone that alters depending on what time of year it is.  If you was to live somewhere that has  multiple times zones and you are passing through these time zones and you have the automatic clock set is an easy option of you having to not change the clock on the device manually.  But in the UK it's not really necessary.
Not really necessary but more accurate Smiley Wink!
Hi @jrp1950,
Welcome to the EE Community.
Are you having this problem with the main system clock that shows in the status bar at the top of your phone, or with a clock widget on your home screen?
James​​​​​​​
by jrp1950
Both, as far as I can tell.
Thanks @jrp1950
Have you recently upgraded your software or downloaded any new apps?
It may be worth backing up your phone and completing a factory reset to see if that solves the problem.
- James
Go into settings - applications/apps - find the clock then clear its data & cache then restart the phone.
See if that helps.
EE Employee
Would you say the clock on The Elizabeth Tower is not accurate ?  last time i checked this didnt have automatic clock time control.  Its manually controlled and its within 1 second of being accurate.
