by Teridahl265 Investigator
Why havent i had emails or messages about my upgrade
I ordered an upgrade from my sim only contract to the huwawei p30 got an order number but no emails or texts and it eont let me track the order
8 REPLIES 8
Upgrade
by Ace Contributor
Re: Upgrade
Hi @Teridahl265
may I ask how you ordered? Was it online or over the phone?  Also, are you having it delivered to home or via store pick up?
If you ordered online, it usually gives an estimate to delivery times. Downloading the DPD app is helpful as when EE book a delivery slot, the app sends you a notification of when you can expect your parcel.
For peace of mind, you can always call 150 and an advisor can help you with the current status of your order.
Re: Upgrade
I ordered it online and to have it delivered to my house
Re: Upgrade
Re: Upgrade
On friday. I have an order reference number xko.... but it isnt the correct number for dpd. And ee website wont let me track it
Re: Upgrade
Hi @Teridahl265
As @Watkins07  said, give EE a call on 150 and check your order is still on track, if the tracker isn't working.
Re: Upgrade
@Teridahl265 The XKN number is just a order number it’s not a tracking number. EE have have taken your order but have not processed it to give you a tracking number.  I would call customer services just to check the order has gone through correctly as sometimes EE might need to speak with you about the order.
EE Community Team
Re: Upgrade
Hi @Teridahl265,
Welcome to the community 🙂
As soon as your order is full processed by our team, you will receive confirmation and your tracking number.
Our customer care team will be able to check your account and give you an update on your order process.
Let us know how you get on once you have spoken to them.
Alex 🙂
