by Sarah69 Contributor
Why does my phone switch off when the battery reaches 30%?
My phone is about 18 months old and has started to turn itsself of when the battery reaches 30%. The battery also seems to drain quite quickly. I bought a new battery but it is doing the same. Can anyone help?
Re: Why does my phone switch off when the battery reaches 30%?
Samsung galaxy j3
Hi @Sarah69
What phone do you have?
Google Pixel phones used to have this problem. Google used to replace them as it was a motherboard issue.
Samsung galaxy j3.
Hi @Sarah69,
Welcome back to the community.
Have you checked to see if there are any software updates available for your phone?
Do your battery settings show if it's a particular app draining your battery?
I did a factory reset on my phone and battery is slightly better. Still turns off at around 25-30%.
