by Chelsy Contributor
Why does my phone keep unconnecting to my signal booster box?
My phone goes throughh stages of connecting then unconnecting to my ee signal booster box. The router is a brand new one so i know its not this and theres only so many times i can reset the boxes.
Re: Why does my phone keep unconnecting to my signal booster box?
Hi @Chelsy
What phone do you have? It maybe your phone is connecting to EE VOWIFI service or the EE network so doesn't need to use the 3G signal given off by the signal box.
If your phone is using EE VOWIFI service you don't need the signal box.
Thanks,
Good morning @Chelsy
Thanks for coming here to community 🙂
I hope the answer given by @Northerner has answered your question?
If you need anything else, please come back and see us
Cheers
Richard
I have a the samsung galaxy s8 edge.
Hi @Chelsy
Thanks for answering @Northerner
I'm sure he will be along soon to try and help you further.
Thank you
Richard
Hi @Chelsy,
If you have an S8 you wont need the signal booster as it will connect to EE VOWIFI service, that is if it’s a UK single sim phone.
Where did you get it? If its compatible look under phone – (three dots) – settings -wifi calling.
Thanks,
