Highlighted
by Investigator
Why does it say my account is cancelled
When I try and log in to ee shop it says account is cancelled,  why?
Highlighted
by Ace Contributor
Re: Why does it say my account is cancelled
Hi @Leighgold
If you ring 150 they will be able to delete your MyEE registration and set you back up you should be able to access the shop area then.
Highlighted
Good Afternoon @Leighgold
Are you able to successfully log into your My EE app?
Have you recently made any changes on your account?
Speak soon, Katie 🙂
