by Draught Investigator
Why do I receive text messages twice
Good afternoon campers
ive just put my SIM card in a Huawei Mate 10 Pro, from an iPhone, and I’m getting text messages twice, spaced 1 minutes apart.
any thoughts? I’ve tried re-setting the network settings...
cheers
Solution
Re: Why do I receive text messages twice
Hi @Draught
Thanks for coming back to us 🙂
Can we consider this as now resolved?
Cheers
Richard
6 REPLIES 6
Good afternoon @Draught 🙂
Are there any maintenance works in your area?
Has this happened when receiving from more than one sender?
@Draught  Did you turn off iMessage on the iPhone before you took the SIM card out ?
I didn’t Chris, but I’ve com,eyed apthat step now and... no dice 😞
i should add that it’s not from every number, only one.... so far at least. That sender also has a new handset.
Thanks, @Draught
Do you know if the text message shows as sent twice on the sender's phone?
Just the once from their side but it turns out other people were getting it twice, so a coincidence. Emergency over.
Solution
Hi @Draught
Cheers
Richard
