by Trotty21
Why did my £10 everything pack run out 2 weeks after toping up
Solution
Re: Why did my £10 everything pack run out 2 weeks after toping up
Hello @Trotty21
Thanks for coming here.
Is this data, calls or texts that have been used?
You can start a new pack early if you have used the allowances for the month 🙂
@Trotty21   Only you can answer that as we don’t know how you used up the allowances as this is a public forum.   Your device will show you out going call times. Your device will show you what apps have used what data amount.  And as for text...
Solution
Hello @Trotty21
