Highlighted
Which phone is best Samsung s10plus or iPhone xanax
Highlighted
by Brilliant Contributor
Re: Which phone is best Samsung s10plus or iPhone xanax
Down to personal choice
I would say the S10+
@Chris_B would say the iPhone.
It all depends what you are used to.
What phone do you currently have?
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
Highlighted
@Jeet   That’s the most asked question by people who don’t actually need the device for any particular reason other than to have the must have gadget.
Its going to be your device so it’s up to you on what you believe is better.
( Is it better though best think about it a bit more 😁
