by Expert Contributor
Expert Contributor
Which handset?
 Evening all,
After a bit if advice regarding my upgrade which is due in about a month..... What peoples opinion on Samsung S8 and Note 8?
Currently I have S7 edge but I also have a Note 3 as spare.
I was going to get Note 7 as upgrade but went for S7 as we all know what happened to the N7😝
Re: Which handset?
If you want the note size but better shape then the S8+ is a better option. Got one myself over the Note 8.
I would however consider what you intend to use it for and how it fits in your hand etc. Go into any store (regardless of carrier) and try them out.
Re: Which handset?
Thanks for helping @Northerner.
Let us know what you decide to go for @Rogersdave771 🙂
Expert Contributor
Re: Which handset?
@Leanne_T @Northerner I have done a little research on the handsets and read lots of reviews.
I think the decision will be made by which handset/plan is cheapest when I come to upgrade ☺️
Not had either handset in my hands yet but will do in the next few days.
Re: Which handset?
Hi there @Rogersdave771
It would be great to hear what you go for and your thoughts 🙂
by Brilliant Contributor
Re: Which handset?
I second @Northerner on the S8+. I have had it from release and its a great piece of kit.
My work colleague has the Note 8 and the only difference I can tell is that the shape is a little more sqaure and the S Pen.
If you are going by price then it'll most likely be the S8+ anyway as this would be cheaper.
