by FlyingV Valued Contributor
Valued Contributor
Where do I get Android7 When it comes out?
I recently bought an S7 Edge via CarPhoneWarehouse with an EE contract. I think the phone isnt locked to EE because I had my TalkTalk Sim working in it for my main number till i ported it over to EE. So do I get Nougat from EE, CPW or Samsung?
FV
by Brilliant Contributor
Solution
Re: Where do I get Android7 When it comes out?
@FlyingV Hi you will get it from whoever the Csc of the phone is it may be BTU or some carphone warehouse phones are using Ireland CSc
But it will be coming direct from Samsung
That may sound confusing but all it means is your phone will tell you when there's an update available you can check for this manually by going to settings then about device then download updates manually
7 REPLIES 7
Solution
Valued Contributor
Thanks for the reply. Yep, I've been checking manually, but nothing as of yet. The phone is showing:
Original CSC Code: (Nothing there)
Firmware's CSC Code: XEU
Active CSC Code: XEU
Available CSC Code (Nothing there)
CSC Country: UK & IRE / GB
Mobile Operator: EE / 23430
I'll keep an eye on the Samsung website then.
Thanks again
FV
Enter *#1234# into the dialer and post the three sets of code.
Valued Contributor
AP: G935FXXU1BPJG
CP: G935FXXU1BPJG
CSC: G935FXEUIBPK2
Your firmware is XEU which is UK/Ireland. Android 7 isn't available yet according to Sam's mobile
Valued Contributor
Ok, Thanks.
You could if you feel confident flash BTU firmware on as this has been updated to Android 7.
But XEU shouldn't be too far behind now.
