by Cv1
When will we get the Android Oreo update for Note 8
by Brilliant Contributor
Solution
Re: When will we get the Android Oreo update for Note 8
You need to aim that question to Samsung.
They haven' even released it yet. The S8 will get it before the Note 8 and we are only on the beta stage (a select few)
It won't be for awhile yet.
And EE won't give out any timeframe
Solution
