Highlighted
When will I get the android 9 update for my p20 pro
Highlighted
by Brilliant Contributor
Re: When will I get the android 9 update for my p20 pro
Hello @Tuggsbunny,
Welcome to the community,
Unfortunately, we do not know. It will be available once EE release it or Android do in this country or for the network.
Make sure you have automatic updates set on your phone and as soon as it is available, you will receive the update.
Highlighted
Hi @Tuggsbunny,
Welcome to the EE Community.
Huawei have started to roll out the Android 9 update to P20 Pro users. It's done in batches so not everyone will receive it at the same time.
You'll receive an automatic notification on your phone as soon as it's ready to install.
Hope this helps.
