by james_uk
When will Huawei P30 Pro be getting updated to 9.1.0.153?
Anyone know when the p30 Pro will get the 153 update? Loads of places have already got it, EE seems a bit slow?
Re: When will Huawei P30 Pro be getting updated to 9.1.0.153?
Hi @james_uk
EE test the firmware to ensure its compatible with it's handsets, running EE version of the firmware. EE will then release it, if there are no problems.
Your device will then tell you when any new software is available.
by Ace Contributor
I only received it last night on my SIM free version. Huawei seem to have a very strange release procedure. I've not seen anyone say that they've got it from any UK network so far.
