by Aperson
New Member
When will Android nougat become available for the xperia xa
Hi all,
Just wondering when android nougat would be available for xperia xa devices as my phone says it is up to my network provider to release it. Thankyou in advance.
by Brilliant Contributor
Solution
Re: When will Android nougat become available for the xperia xa
Hello @Aperson,
Welcome to the community,
No-one here in the community will know when it will be available, even if Android have released it, EE will do their own tests to make sure that it is compatible and work with the software they install, as they do not want to release it and then get complaints that customers are having problems after installing the update.
Your phone will let you know when the update is available, if you have it set undress settings, to update. Oh, and by the way, your phone is correct, it is up to your network provider.
Solution
Hello @Aperson,
