by sutty177 Investigator
When will Android P arrive on my Galaxy S9 Plus?
According to the Samsung website, this upgrade should be rolling out already???
by Brilliant Contributor
Re: When will Android P arrive on my Galaxy S9 Plus?
@sutty177, I doubt you will find the answer here, as it depends when EE will release it, as I believe they test it first.
Once it is released, you should get notification if you have automatic updates set on your phone.
by Graeme2812 Established Contributor
If you pruchased your phone from EE directly it will most likely have EE firmware and therefore it may take a little longer for EE to test with Pie before the release to the public. (Wi-Fi calling and VoLTE compatability for example).
If you have an unbranded/unlocked handset you should probably start getting it sometime this month as that has been the general timeframe (January 2019) that is being talked about. I've yet to read anything more specific.
As a sidenote, I have an S9+ and the VoLTE upgrade came relativly quickly after it was implimented across the board.
It's not out on any network or unlocked versions in the UK.
by Smiler28 Investigator
I've just manually checked for any software updates this morning and the upgraded One UI Android Pie download is ready/ available to download on my (Contract) S9 Plus.
