Highlighted
by Investigator
When is the Huawei P9 going to get the Android 8 oreo update
  1. When will the Huawei P9 get the Oreo Android 8 software update
Highlighted
Re: When is the Huawei P9 going to get the Android 8 oreo update
@Seandykes83  When Huawei  create the firmware that EE are happy with and that it doesn’t have any issues,  as EE doesn’t want you to have issues with that firmware.
Highlighted
New Member
Still waiting for the update.
Highlighted
@Rosegc   That update is down to Huawei to crate EE only have to test and approve it that’s if an update is coming for that model type device and as I said that’s down to Huawei to create.
